1 - 5 of 5 Posts
Ok I have a problem with my truck when I turn the key to the run position it is fine until I turn the key to the start position then it pops the starter fuse. has anyone had this problem? If so what was it? If not where should I start? I am at a complete loss on this one on where to start :(
Still learning
I would unhook the starter solenoid and try it. If it does not blow fuse you're looking at the starter solenoid or starter. If it pops the fuse start tracing wires back to key switch. GL
Still learning
Starter solenoid the little wire. When you turn the key it trips the "switch" for the big wire to engage the starter.
1 - 5 of 5 Posts
