LMFAO. Least it wasn't a head gasket! :swordfight:OOOHHH.....I read that wrong...... I thought you blew someone in a duramax
Now that's funny!OOOHHH.....I read that wrong...... I thought you blew someone in a duramax
hahaha, ouch. Too bad my stock setting makes more than that. :gun:Wtih 285 horse I don't think you can blow a head gasketoke:
:stupid: Highly doubt it! I've heard that thing run, and seen it try to run.Too bad my stock setting makes more than that. :gun:
If I remember you got:stupid: Highly doubt it! I've heard that thing run, and seen it try to run.oke:
No but before I clicked on it that is the first thing that I thought but glad it wasn't the engine.Dang? You want me to blow my engine![]()
:shrug:
:ford:
I cant run stock a stock tune in this truck due to running singles, but in the old truck w/o a chip and a TDE1 pcm made upper 400's. Id have to go look at the dyno sheet to see what it exactly was.I can't help but ask......
If your "stock" setting makes 285hp.....what exactly makes it your "stock" setting again??? Mine made like a buck 80 stock, lol.
OBS for the win! Preach on my brotha !I cant run stock a stock tune in this truck due to running singles, but in the old truck w/o a chip and a TDE1 pcm made upper 400's. Id have to go look at the dyno sheet to see what it exactly was.
x2 my actual "stock" runs like balls because its singles on split programming.I cant run stock a stock tune in this truck due to running singles, but in the old truck w/o a chip and a TDE1 pcm made upper 400's. Id have to go look at the dyno sheet to see what it exactly was.
Kenny, blew the fitting out of the pump. The hose that goes from the pump to the hydroboost.Did the hose blow or the fitting.
Losing the steering aint to bad but did you have to change your underwear when you hit the brakes.
more than 285hp in the stock setting:hehe: I thought that was the extreme setting
