1 - 1 of 1 Posts
you can find the info on the hypertech site. for 2001 only.
does all the tuning, diagnostics, even has horsepower and 1/4 times.
uninstalled myself so i know everything is legit.
unit and cable, no mount.
new these were like 799.
will take 200 obo plus the ride.
Performance Tuning
The Performance Tuning Program contains Max Energy Power Tuning and all of the Max Energy features available for your vehicle.
Provides the safest, most powerful, 50-state legal Max Energy Power Tuning™ available for regular and premium octane, as well as 3 stages of engine tuning for diesels.
Users boast of a 2 to 6 mpg increase, even when towing heavy loads.
Allows towing at the maximum weight rating specified by the vehicle's manufacturer, even at the highest power setting.
Allows you to adjust and re-program many other performance features based on year, make and model, as well as return the vehicle to the stock tuning.
Diagnostics
When a DTC (Diagnostic Trouble Code) is detected, the HyperPAC displays the factory code number with a complete description and allows you to clear the code. This allows owners to access information about the vehicle’s operation without having to purchase expensive diagnostic computers or scanners used by dealership technicians. You can then make the necessary repairs to prevent the light from coming back on.
Drag Strip
Monitors real-time engine operating conditions before a run.
Produces a real “christmas tree” start, measures and displays reaction time just like you get at the track.
Automatically displays a time slip just like you get at the track.
Displays “magazine-type” road test acceleration times in ten mile-per-hour increments.
Displays drive-wheel horsepower vs. vehicle speed after each run.
Records and displays engine operating conditions throughout the run.
Dynamometer
Displays drive-wheel horsepower vs. vehicle speed, and engine horsepower & torque vs. RPM, in both table and graph formats.
Automatically corrects horsepower and torque to Standard Temperature and Pressure (S.T.P.), allowing valid comparisons between tests conducted under different atmospheric conditions.
Records and displays a data acquisition report of important engine operating conditions throughout the run.
Diagnostics
Gauges
An advanced gauge package that allows viewing of almost any engine function as analog or digital gauge. User selectable, as many as sixteen different functions may be viewed in digital form or in combinations of one, two, or five analog gauges.
RPM
Mass Air Flow
Trans Temp
Spark Advance
Engine Knock
Throttle Position
EGT (w/module)
AFT (w/module)
Performance Gains
Stage 3: +100HP +164TQ
Stage 2: +60HP +113TQ
Stage 1: +32HP +74TQ
Adjustable Features
Shift Firmness
Speedometer\Odometer Correction For Tire Sizes 29-34 inches 1/4 inch increments
DTCs Read and Clear
Return Back To Stock
1 - 1 of 1 Posts
