1 - 6 of 6 Posts
So my hydroboost is leaking into the cab. Need to replace it, but on a very tight budget. What are my options?
How about some details about the parts you used and where it's leaking from?
Is this on an F-Superduty, or did you convert from vacuum brakes to hydroboost on and F250/350?
Sorry, it's a 99 SD. Has the hydroboost, at first noticed it leaking from the shaft attached to the brake pedal and then saw fluid build up in the engine bay at the firewall.
I'm sure someone here could help you but this is the 94-97 truck tech page. Hit up the superduty forum and you'll probably get a faster answer.
I have 2 working hydroboost units I will sell from 99 and up super-duty's. $100 plus shipping for the pair as they won't fit my 92. I put a hydroboost setup off a 96 F450 on my 92 F350 4x4 last fall. Here's is a link to my local Kijiji ad, there is a pic of them in the ad.
1999-2007 FORD F250 AND F350 PARTS. 4WD ZF-5, 4R100, BW271, V10
BigRigTech, are you willing to cut me a deal on one of the boosters (preferably the better of the two)?
I also just realized I did in fact post int the wrong section. Sorry, and thank you!
1 - 6 of 6 Posts
