1 - 7 of 7 Posts
Have a substansial ammt of totally synthetic un used hydraulic oil. Can i use this mixxed with the diesel? Also have some trans fluid un used layin around what do you think?
I've used some trans fluid before, not sure on the hydraulic oil though.. maybe somebody else will chime in on that 1...
Science rulz
I know that hydraulic fluid will burn.. But it's pretty nasty stuff lot's of toxins in there.
I think maybe a 15%/85% mix to try, but I really think that your exhaust will simply stink so badly that your eyes will water.
I'd stay away from synthetic, not all the additives ignite completely. Used filter ATF is ok, in your truck up to 80% ATF to 20% #2 would work good
So the hydraulic fluid won't burn completely?
1 - 7 of 7 Posts
