Status
Not open for further replies.
1 - 8 of 8 Posts
We In The Money Now
:doh:OK it's my fault i lost the little flash drive that came with my Hydra chip and i wanna hook a scanner up to my obd port to check for codes don't i have to set the chip to 17 isn't that level for that. go ahead laugh at me it's OK i won't be upset, again it's nobody's fault but my own. Any info would help and i guess i'm to lazy to just pull the chip.:doh:
why would you have to pull the chip to check for codes? I just plug my AE in just like every other time
<<< THE GAUGE WHORE...
You dont have to do anything. Hook up your scanner and go...
If for some reason you want to be in the diagnostic mod I believe it is 17, but I'm looking into it right now.
00 is the bypass... 17 is No Start.
We In The Money Now
Thanks for the info, just wanna check for codes and don't wann mess up my pcm or anything i lost 2 pcm with my edge before going with this chip never checked for codes since i put the chip in but again thanks for the info
You will not have any issues with any chip, pulling codes or running any tests...
1 - 8 of 8 Posts
Status
