1 - 12 of 12 Posts
Im thinking this has something to do with the esof not working... anybody seen this?
that would be simulating your air leak. thats why its not working. i have the esof leaking somewhere on my truck too
Administrator
That is completely normal
the hubs are meant to hold vacuum not pressure
that screen is where pressure is vented from
ESOF issues are easy to isolate with a vacuum pump like Mighty vac and a few other procedures
the Esof solenoid valve is a common failure item
Thanks for ya'lls insight, I've been reading everything I could find on the subject and, haven't seen anything about bubbles, kinda freaked out for lack of better term
'05 Excursion
Bubbling? What the heck would be bubbling unless there's water in the hub?
I did just get done washing truck, it's never been submerged or abused off road..... I dunno, im gonna get a pump and see what happens
Administrator
water gets on the foam exhaust filter and when you wash a hot hub it bubbles
it's a closed chamber any pressure is supposed to vent from there
if it were a vacuum problem you wouldn't see bubbles ;-)
I think im gonna take a 60$ chance and buy the solenoid....... I was madder than a hornet the other morning when I pulled off the road to look at car for my daughter, in the rain, in my house shoes, taking off hub caps to lock hubs, only to not be able to move enough either way for axel to engage.....
Administrator
Oh the solenoid is easy to check mine was bad
if you can't find the test via google it's easy I will explain ,,
Mine do the same thing when i wash mine i turn them in and out to keep everything moving because the will freeze up
2 stroker
Solenoid it was....thanks for the input on this and the other threads on this subject.....
1 - 12 of 12 Posts
