1 - 5 of 5 Posts
I've done alot of reading on the search engine and can't figure it out. What is a HPOS? is it inlue of replacing the HPOP by assisting the factory one or Do you still upgrade to something like a 17* pump and then run a HPOS? I'm still trying to learn about Diesel's and any information would help Thanks.
HPOS is High Pressure Oil System.
The HPOP (High Pressure Oil Pump) is what makes up the HPOS.
ok so the purpose of running something like a terminator 2 is to have 2 hpop's instead of just one, Only reason i ask is because everything kept saying syster(as in assisting something is what i got out of it) could have just been typo's though.
a single pump will be fine SD 17 deg pump will handle st1's from there it all depend on what size injectors you going to use
ok thanks
1 - 5 of 5 Posts
