1 - 5 of 5 Posts
2006 6.0, old pump has two piece quick connect fitting which uses a bracket that goes from fitting to pump mounting bolts, new pump has one piece fixed fitting. Do you still use the bracket or delete the bracked and use the shorter bolts that came with the pump? Im thinking dont use the bracket but just wanna make sure. Thanks
1 - 5 of 5 Posts
