1 - 9 of 9 Posts
Canadian Stroker
Can you change the o-rings on the hpop oil line quick connects? Mine looks like it is leaking on the drivers side head quick connect fitting. If so where can I get them?
Thanks
Canadian Stroker
I have the tool to get them off. Which o-ring set is it?
Thanks
wait are you talkin bout where it connects to the head? sry miss read your first post. thought u ment the ones that connect to the HPOP its self
Canadian Stroker
Discussion Starter · #6 ·
Anyone else that CAN help me out??
Canadian Stroker
Discussion Starter · #8 ·
No. Not where it screws into the head. The quick connect fitting at the head. Where the hose connects to the peice that screws into the head. Is there a replaceable o-ring in there?
There is, but I have never messed with them. Just pick it out and try and locate one at the hydraulic shop. Or, run down to Ford and pick up a new fitting(might be easier).
1 - 9 of 9 Posts
