1 - 7 of 7 Posts
Is there any difference between a HPOP on a 2002 and the HPOP on a 1996. The HPOP on the 2002 is bad and i have access to a 96 but im not sure if there is a difference.
Moved in
:whs:
How do you know your HPOP is bad? If you are absolutely positive take a look at the Adrenaline HPOP from DieselSite. Before you spend the money, make sure it is the HPOP and not the ICP sensor or IPR.
And welcome to the Nation!
thanks for the welcoming. good to be here. The pump is on my buddies truck. he just tows a lot with it. it just has a superchips on it. and the high pressure line that goes to the passenger side head blew out of the pump and it took the threads with it:shrug:
Adrenaline!!!! I love mine and it's well worth the money. When I had it installed the lines were replaced also.
The older (up to 99.5) were 15* and 99.5 -03 were 17* On another note, scrap the superchip and get a custom tuned chip from one of the sponsors on here. Safer for the eng & trans. My dp in 20T puts out more sotp power than stage III (100hp) on my old hypertech. Tows much better and trans controls are wonderful. A JW or BTS valve body will help the trans live longer also. Just my $.02.
Welcome to PSN.
That pump can be repaired, NO problem.
Let me know if I can help. I also sell New Bosch pumps, with a 2 year warranty.
1 - 7 of 7 Posts
