1 - 4 of 4 Posts
So I took the HPOP off to replace all the o rings since it was leaking. My truck is a 1995 and it looks like the previous owner already changed out the high pressure lines from the HPOP to the heads. I bought the special tool to remove them only to find they are simply threaded on so Im assuming they are the aftermarket lines. When I removed the fittings from the high pressure lines on the HPOP the springs were still in there. Do I still need the springs even though Im not using the factory quick release fittings? Thanks
1997 F-350 CCLB 7.Tree
remove the springs, and most older 7.3 dont have the ones that require the disconnect tool.
Trust me, I got this...
To be more precise, the 94-97 are the JIC connections, the 99-03 are the quick connect (from the factory). Some people like to convert the quick connect to the JIC style.
Sent from my LM-V350 using Tapatalk
1 - 4 of 4 Posts
