1 - 4 of 4 Posts
So I replaced me HPOP O-Rings and fittings, in the process I damaged one of the HPOP Lines, I got an OEM replacement from FORD and its not the same as what I had. My stock ones were small in diameter and stainless steel braided. My new one is about 1 1/4" in diameter and brown rubber. My question is this: If they are different from the left to the right side is there going to be problems. The ID of the hose appeared to be the same but the OD is way different. thanks in advance.
-Jason
Strokin' in Green Bay
Ford changed the design of the hoses a while ago, you have the right ones. Supposedly they are better than the originals. The ID should be the same so you should be fine running one of each kind. When I changed mine one of them doesn't have an elbow on the end like the old one, so it runs high in the valley instead of low if that makes sense. They fit and work good though.
Cool. Thanks
OEM Moderator
You should post up a picture of these new lines. These is fresh information to me.
1 - 4 of 4 Posts
