1 - 9 of 9 Posts
Cummins?$?$?$?
I ve got this '95 with the 15degree pump in it, its bad im looking to find a reman cheap, but i think putting a 17degree pump in it would be smarter, with the injectors, so question is my HPOP doesnt have the anti-drain back, nor the the quick fittings, like the 17's come with so what can i do to make it work and is it gonna be cheaper then getting an adrinaline??
Old But Sexy
you could do a adnerline pump from diesel site
I will third opinion for the adrenaline.
matt z
Another option would be to email Joey at Terminator and talk about send in a sd 17* pump along with your 15* pump so he can swap the internals so you then have your 15* housing with 17* internals.
I can do the swap. It's relatively cheap, if you supply the 17.
PMS medication required
Anyone know the cost to upgrade a 15 to a 17 or is this not possible?
Cummins?$?$?$?
Discussion Starter · #9 ·
So, adrenaline is cheapest and just as good??
1 - 9 of 9 Posts
