1 - 6 of 6 Posts
Hey all,
Which way does the HPIP turn if your are in front of the pickup facing the engine?
Clockwise or counter clockwise?
Info needed ASAP
Thanks
Jake
What is a HPIP?
I thought it was the High Pressure Injection Pump
09 6.4
HPFP (high pressure fuel pump)
anywho, the engine rotation facing the flywheel is counter clockwise...thats at the crank, but the HPFP runs off the cam gear which runs off the crank gear...so i dont know if that means the HPFP turns opposite or the with the crank
So the fly wheel turns counter clock wise, there for the cam would turn clock wise, and and the hpfp would turn counter clock wise, Thank you, do you know if the 7.3 turns counter clockwise facing the flywheel?
Thanks
Jake
09 6.4
pretty sure the 7.3 turns counter clockwise facing the flywheel as well
1 - 6 of 6 Posts
