1 - 8 of 8 Posts
Alright guys I got what looks to be a plastic oil rail on the bottom side of my valve covers that has fittings going to each cylinder feeding the injectors. are those my hp oil rails? if so i put in an adreniline hpop and it has literaly pushed that damn rail out of the head! any body know where i can get new o rings? do the rails bolt on or do they push on? (my battries died in the mag lite i cant see anything holding them in) any help?:mad:
Ununited11
Pull the glow plug bus bar off and check the o-rings on it where it goes into the rocker carrier. All that is inside of that rail is the electrical harness for the glow plugs but it does have o-ring seals on it that could be leaking oil out of the rocker carrier
Do a search on this thread, this just happened to another guy not too long ago, see what his final fix ended up being.
1 - 8 of 8 Posts
