1 - 3 of 3 Posts
What is the easiest way to test ipr? truck wont start just cranks ficm shows 48 volts truck throwing codes for icp sensor changed it still the same.. hpop showing 5.7 psi at crank im just trying to rule out if ipr is bad before i tear into it.. Also are there any specific special tools i need besides basic ones if i have to pull hpop to check the fitting and pipe on it?
yup had ball valve out.. ordered an adrenaline pump..
1 - 3 of 3 Posts
