1 - 8 of 8 Posts
Wiper motor is shot. Is it as simple as remove the wire harness and the bolts and slide it out?
99 f350 7.3
Unfortunately, you have to buy the whole assembly to replace the motor.
Basic breakdown:
Disconnect the hose for the wiper fluid.
Remove the wiper arms.
Unscrew the plastic shroud at the bottom of the windshield.
Remove Antenna.
Remove hood seal.
Remove Shroud.
Disconnect wiring harness from wiper motor.
There were 4 or 5 bolts that hold down the wiper assembly. You may have to turn the motor manually to get it in a position to get it out. Remove the bolts.
Have fun trying to get it out, then the new one back in.
Not sure if I forgot anything.
Easy as pie. Thanks.
half hour job, do as described above. You can get just the motor.
Where? Everywhere I looked they only had the whole assembly.
any parts store. I just got one from advance auto.
2004 f-250 6.0L , Washer inop only... Pump checks out. I understand that washer pump operation is relayed or such in the wiper motor.. Is this true, and will a new wiper motor likley fix the washer issue ??
Thanks,
Danno
1 - 8 of 8 Posts
