1 - 19 of 19 Posts
· Registered
Here is a relatively cheap way I found to build your own Ford blow-by measurement tool.
Here is the actual Ford tool that connects to the engine as well as the magnehelic gauge, in the Ford gauge bar, that reads the pressure.
It is basically just an open pipe that connects to the oil fill hole in the valve cover. On the top end of the tool is a .40" diameter hole and on the side is a fitting to connect a hose that goes to the pressure gauge.
The cost of the Ford stand pipe and adapter that connects it to the engine is over $100. I couldn't justify that so, I built my own out of an old Ford oil fill cap and some PVC pipe. The first step was to take apart the oil fill cap and drill out the bottom part that screws into the valve cover. This hole needs to be larger than .40". I found that 1 1/4" PVC pipe fits nicely into an existing groove in the oil fill cap. After cutting the pipe to ±6.0" in length, I drilled and tapped an 1/8" pipe thread hole into the side of the pipe. I then installed an 1/8" pipe to hose barb fitting that will connect to the pressure gauge hose. Once that was done, I cleaned the cap really well and glued the piece of pipe into the groove in the cap using super glue. The last piece is the cap for the pipe with the required .40" hole drilled in it. I found the magnehelic gauge on eBay for under $20. There was a pretty wide selection with quite a few available when I bought mine. Another option would be to build your own u-tube manometer. http://www.komar.org/faq/manometer/
If you go the magnehelic gauge route, it will have four 1/8" female pipe thread ports in it. Two for high pressure and two for low pressure. One of each will be on the side of the gauge and the other set is on the back. You want to plug one of the high and one of the low pressure ports. Then connect the hose fitting to the remaining high pressure port while leaving the remaining low pressure port open to atmosphere. You can connect to either the side or back high pressure port - whichever works better for your setup.
To test blow-by, ensure engine is fully warmed up and plug or pinch off the CCV. Hold engine at near WOT in park and take the blow-by reading. Results will be in inches of water column. Less than 4" of H2O is a pass for the 7.3.
I didn't glue the cap onto the pipe of mine as I wanted to also use this setup to measure how much restriction my CCV mod was causing. I can do this by installing a cap with no hole in it onto the pipe and then run the pressure hose into the cab to monitor crankcase pressure while driving (with the CCV open). Another reason to not glue the cap on is that I think the 6.0 requires a smaller orifice than the .40" used on the 7.3. Having two caps, one for each engine, would allow the tool to easily be used on both engines. Also, the pressures we are talking about here are so small that I don't think there is any danger of the caps ever blowing off. It takes 27" of H2O to reach 1 psig.
Shawn
· OEM Moderator
A very nice thread that will be added to the library eventually. Good work Shawn.
· All done now
You beat me to it Tom. That is for sure Library material. In fact, I think we should have a library for hombuilt tools like this. They cross a lot of Powerstroke platforms. Or can we put them in multiple libraries.
· Registered
Discussion Starter · #4 ·
Yeah, I wasn't sure where to put this since it is so generic.
Shawn
· All done now
Excess cylinder gasses getting into the crankcase. Bad rings, or a hole in the piston. Nothing good.
· Fixing Broken Stuff
Good idea, i'm going to make one.
· Registered
Discussion Starter · #8 ·
I had a PM request for more pictures of this, so I thought I'd add them here.
This shows the back of the magnehelic gauge and what to do with all the different holes.
Shawn
· Registered
Thanks for the useful info and pix Shawn!!!! Have you tested your CCV open vent for restriction values? Would be interested to see your results.
jrc
· Registered
Discussion Starter · #10 ·
jrc
Are you asking for the crankcase pressure differences between the CCV routed to the intake, in the stock configuration, vs an open road draft tube out the bottom of the truck?
Assuming yes, I essentially saw the pressure cut in half by removing the CCV from the intake. It's been a while, but it went from something like .4" H2O to .2" H2O.
I had installed a CCV catch can identical to this one when I first bought the truck. It basically routes the CCV gases into a large diameter pipe filled with kitchen scrubber pads and then routes it back into the intake in the stock location. I still had some oil getting past the scrubber pads and into the intake and this is what led to my building this tool - I figured I had excessive blowby. Anyway, with this CCV catch can installed and a closed cap (one without a hole drilled in it) installed on the blowby tool I measured a max crankcase pressure of around .4" H2O.
I then removed all the scrubber pads, essentially returning the CCV to stock, and measured .4" H2O again.
Next, I pulled the inlet hose off the CCV catch can and left it hang out the bottom of the truck right behind the transfer case. I measured .2" of H2O and the truck seemed to run noticeably better. That's where I still have it today.
That .2" H2O drop in pressure is equal to .007psi. I wouldn't think that would make a difference, but it did on mine.
Also, I'm sure this all depends on how much engine blowby is present to begin with. Mine is 2.5" H2O.
Shawn
· Registered
Shawn
so the top of the pipe should have a hole in it?
· Registered
Any one have one they would loan out, I pay shipping cost??
· Registered
anyway to take pics on how this tool is set up to use on the truck...
· Registered
Discussion Starter · #15 ·
I lost my camera on vacation, but it's pretty straight forward. Assemble the tool as shown below. Remove oil fill cap from engine valve cover and install tool in its place. Connect small hose between the tool and the gauge. Plug the CCV hose on the opposite valve cover and test.
Shawn
· Registered
Anyone else checked blow-by with one of these or had a dealer perform this test? Would like to see some other results.
· Registered
Discussion Starter · #17 ·
I had a PM request to update this post since webshots died and took the pictures with it. I redid my original post again with the pictures below.
Here is a relatively cheap way I found to build your own Ford blow-by measurement tool. It is basically just an open pipe that connects to the oil fill hole in the valve cover. On the top end of the tool is a .40" diameter hole and on the side is a fitting to connect a hose that goes to the pressure gauge.
The cost of the Ford stand pipe and adapter that connects it to the engine is over $100. I couldn't justify that so, I built my own out of an old Ford oil fill cap and some PVC pipe. The first step was to take apart the oil fill cap and drill out the bottom part that screws into the valve cover. This hole needs to be larger than .40". I found that 1 1/4" PVC pipe fits nicely into an existing groove in the oil fill cap. After cutting the pipe to ±6.0" in length, I drilled and tapped an 1/8" pipe thread hole into the side of the pipe. I then installed an 1/8" pipe to hose barb fitting that will connect to the pressure gauge hose. Once that was done, I cleaned the cap really well and glued the piece of pipe into the groove in the cap using super glue. The last piece is the cap for the pipe with the required .40" hole drilled in it. I found the magnehelic gauge on eBay for under $20. There was a pretty wide selection with quite a few available when I bought mine. Another option would be to build your own u-tube manometer. Manometer
Shawn
· Registered
I finally got around to making one of these for my rig. very easy to do and use. At idle I had 1 psi and then at 3k rpm it measured 2 psi. Both of these reading were done on a warm up to temp engine. Thanks
1 - 19 of 19 Posts
