So what all would be needed to convert a 7.3 complete motor out of a truck to marine use? Take for granted your looking for the most speed you can get out of it.
You think Danny is gonna throw in a stock motor and call it good? I think not!Danny look at these
http://www.sea-pro.com/mercurymarine/mercruiser/sterndrives/diesel/D7point3L-D-Tronic-LD.htm
http://mercruiserparts.stemtostern.com/MercBlockDisplay.aspx?DocNumber=803737
I spoke with a mercruiser technician back when I first got my truck asking him how the engines do in a boat. His answer was simple: Not Good. The engines suffer from valvetrain failure because they were not designed to sustain high rpm at full load for hours on end. They were having problems with bent pushrods, bound springs, dropped valves, bending rocker arms. It wasn't a good list of things to break. The problem lies in that the engine just isn't designed to sustain 3600 rpm for hours on end.
Yes you guys are getting HUGE hp out of your race trucks, and you are exceeding 3600 rpm by quite a bit, but it is only for a very short amount of time. That high rpm pounding had a bad effect on the longevity of the engines. The application was so rare that i've never even seen one. it was only used for about 10 years, and for boats in that size range of a single bigblock outdrive, most people probably wouldn't bite for the extra cost of the oil burner. Remember, 10 years ago gas was dirt cheap, especially when you get a tax credit for the road tax charged on marine gas at the end of the year.
oh BTW, i saw the article about the D-max and its fighting weight is 2600lbs. What are you going to try and get the fordota down to?
I thought you were going to say Banks has a kit for it...It wouldn't cost a lot to buy some of those parts and compare them.
It's called "Fresh Water" cooling as oppossed to "Raw Water" cooling.Do they coat the water passages or will the cast iron block hold up to the fresh/sea water.
