1 - 6 of 6 Posts
Anyone know how to avoid the p0541 removed air intake heater code?
can you put a small value resistor between the relay and ground? to make it think it's still there?
i kno some site sells a code eliminator but i unhooked mine and have never got the code....knock on wood.. i'll see if i can find that website for u so u can get an idea on what u need
anyone know what value of resistance is used?
All done now
I bet it is a time delay resistor. It works for so much time when the key is turned on. Then becomes a short. Need to simply use an ohm meter to ohm across a AIH relay while it is working, and a stop watch to see how long it works for.
I think something (resistor) needs to be in series with the switched hot pin on the AIH relay/solenoid, and provides a resistance to ground, the computer controls the timing with the switched feed to turn on the AIH relay/solenoid.
I'll try and dig my old AIH out in the shop and meter it out. then I can figure out what wattage is required.
1 - 6 of 6 Posts
