1 - 15 of 15 Posts
How do the lines come off of the fitting in the head and on the HPOP? Where can one be purchased at? What is it called? Thanks.
All done now
I did it with a modified scredriver (I sharpened the edge down like a chisel). slid it in the thin gap and twisted it. It worked perfect.
The real tool looks like a small pickle fork. The ends of the fork are really nice edges. You just kind shove it in and it seperates. Kinda like a chisel with a slot cut in the middle of it.
After the last fiasco this should be a snap :poke::poke:
btw- Don called tonight for an update, said he thinks he has the tool
Do you know where this can be purchased? Snap-On?
You can get one here But take a look at how easy it is to make. I used 1X8X1/8 inch metal stock and drilled a 1/2 inch hole in one end and then cut that end off leaving a bit more than half of the hole. Look at the tool and you will see what I mean. I don't make everything I don't have, but for things like this it is too easy and your done.
If you're only replacing the o-rings for the HPOP fittings you do not need to remove the lines from the fittings. You can turn the fittings off with the lines attached since they swivel 360* on the fittings themselves.
Canadian Stroker
Where is the best place to get the o-rings. Mine looks like it is leaking where it screws into the drivers side head.
Thanks
Thanks
The HPOP o-rings are available in a kit with the loctite from Ford. I am sure you can get them from Guzzle as well.
You will want to fix that leak soon, if it gives way you will have a huge issue and a huge mess.
Amen. When mine went I didn't know it. Came out to leave and there must have been a gallon on the driveway and a mess in the valley.
All done now
I third that. That's why I bought extras. They will leave you in the worst place.
1 - 15 of 15 Posts
