1 - 6 of 6 Posts
Alright I cant figure this one out, and I'm sorry if I don't use the proper terminology etc.
I have an accessory that is switched-ground. I want to use a switch that is illuminated. When the accessory is turned on I want it to light up. The problem I'm having now I think is obvious at this point negative switched= no power= no light.
Any help would be appreciated.
Super Moderator
Just add a standard relay.
So from the switch run a wire to post 86 and from 85 and 87 goes to ground. 30 comes from the accessory.
So just want to make sure I got this. One side of switch to 86 other side from switch to 85, 87 ground 30 accessory, 87a?
Sorry for some reason I am having a tuff time comprehending relays and i knew it was what I needed just didnt understand how it was going to work.
Thanks for your help
Super Moderator
So from the accessory part of the switch goes to 85. Then 86 and 87 go to ground. And 30 is the ground from your accessory. 87a is not used.
Super Moderator
1 - 6 of 6 Posts
