1 - 19 of 19 Posts
All Talk, No Walk?
Darn shifter knob broke on me this morning. It looks like I can unplug the wires and unscrew the broken part. Am I even close? LOL
28 cent #2
My buddie's did this in his F-150. We used gorilla glue haha still holding to this day you just got to know shift down into drive using more of the bar not the end haha.
All Talk, No Walk?
Only reason it broke was because my linkage is just a hair out of wack, so sometimes it doesn't completely go into park, unless I slam it just a bit. I felt it loose the other day, but didn't think nothing of it, till it broke on me this morning... :doh:
While you're at the dealership getting a shifter pick up the plastic alignment bushings. (I don't really know what they are called) but they hold the shift rod in the column in place, it helps a lot. Also look under the dash where the steering column enters it you will see the shift rod linkage make sure it's nice and snug.
Someone on here has a couple of good pics. Hopefully they'll see this and post....
Not Winning.
I can fix anything, where's the duct tape?
<---mud
super glue works fine for that.
Catfish Mafia
same thing happened to me.. superglue still hoding a year later!
HA HA RYAN!!!!!, must be the Iowa heat!!, Mine did the same thing sunday afternoon!!!!!!!!, SAME EXACT THING!!!!lol, Mine will be getting superglued back together, and some electrical tape over it!, good luck with yours!.......
All Talk, No Walk?
Discussion Starter #15
Must be :hehe:
dinnerbooter treasurer
I had the bolts under the dash come loose on me. There is also an adjustment on the transmission that you can make easly to adjust were the shifter is in relation to the trans. Good luck Ryan.
Busy Busy
Adjust the linkage at the trans so it goes into park as it should when you are done.
What else?
Boy that sounds nice and safe, get the bushings, they are a whole $5. And get a new shifter, the wiring where it comes out of the stalk in the column is most likely almost worn through. :poke:
Dave
Banned
new shift lever,use your old od switch,remove top and bottom covers,unplug the 2 wire connector,drive out the pivot pin.
1 - 19 of 19 Posts
