I just started playing with this tune, but I think it smokes way too much for around town driving. With each shift I am letting out a cloud. It attracts a lot of attention. Any way to clear this up?
I just read this part of your post...........if you don't want it to smoke you will probably need to use a stock setting or see if some custom tuning will help.I am at high elevation
Tell ya what my 100 HP reflash is real smokey if it is in od and I have to drop speed down under 55-60 and I need to accelerate I usually piss somebody off I cannot wait to get new tunes.The 80e smokes also, but I only use that on the highway and smoke only shoots if I make an authorative pass. But around town with a 6 spd where I build boost, shift and start all over again, it can get damn smokey. The 60 does it also, but it is ok. The 80t is just flat out too smokey. If a cop was behind me, I'd be sweating. I eventually need to get to Jody for some fine tuning. But, I will check the boost pressures.
Tbar
man that sucksRight up untill you get a pollution ticket..500 large in Jersey......go figure
It's because of that extra pedal and shifter on the floor. Full boost, shift and have zero boost, makes smoke.My 2000 smokes and has stock injectors just a little gray haze but smoke good I wish I had more smoke ask Joey:rockwoot:
