1 - 11 of 11 Posts
I just installed my gauges. And my tow max gauges says my fuel pressure is at 45psi at idle. But also the needle doesnt bounce at all ?
Does the line have any kind of snubber in it that would dampen the pulses? I hope it is using an electric sending unit and not actually running a "live" mechanical fuel line into the cab (never a good idea). Cheers!
Yes its a electric sending unit. Idk if the sending unit has a dampener. How accurate is it. They are glowshift gauges so i know they aint top line. The truck runs fine doesnt sound like its starvin for fuel.any ideas to double check the fuel pressure so that i know. But i also know the pump is old and is leaking fuel out of the weep hole?
Well when you dont make money hand over fist. You make do with what you can.
There you said it. Glow S H I T
another inciteful post from our PSN local, Brad.
I would imagine the gauge being accurate to within a few lbs. not sure on the fuel pressure, but I thought it was to be somewhere around 65?
did the sending unit come with the gauge?
STILL LEARNING
Well when the Cheap EGT gauges is reading 1100* yet you are actually running at 1400* you will be saving NOTHING
Just use a tire gauge on the shrader valve. It will give you an accurate reading enough to tell if your glowshifts are the sheets.
I would also look at putting in a car spring. I have found them weak. The bb mod to help put will slowly lose pressure over time.
I have autometer z series egt. Just my boost n fuel are towmax. They match ok
45 psi on a basically stock truck should be OK. 60 psi is the target everyone shoots for. I put a "california" fuel psi regulator kit in mine, last scheck 60-65 at the schrader. The fuel psi sender will likely die quickly due to pulsations. I'd hook it up, do some tests, then remove sender or valve it off untill needed.
1 - 11 of 11 Posts
