1 - 7 of 7 Posts
Got Bost???
Is re torque necissary when re using h11's? If so what is the final torque pattern?
Thanks
HP Junky
Hot retorque should be done with fire rings. Yes. Probably get a good 1/4 to 1/2 a turn on each stud after the first initial start-up and good heat soak cycle. The WOP Fire Ring kit and H11 studs should be torqued to 135 ft-lbs.
Crazy Talk
whats the sequence for the retorque? same as final is normally, left to right then up a row?
Crazy Talk
i was goin by di's site. first two torques from middle out then the other way for the final. thats how i always done it.
1 - 7 of 7 Posts
