05 6.0 studded deleted everything got a hot no start so replace ipr icp then replaced hpop ..still had issues started cold instantly and had great pressure when running hot or cold but but once hot and shut off it would only build anywhere from 200icp psi to 300icp psi ipr at 84% then Did the dummy plugs and stand pipes drivers side stand pipe had blow apart oring so thought I found the culprit did both dummy plus both couples but only the one stand pipe bc of clearance issues on passenger side ran great for like a week started hot or cold then today on the way home from work I shut it off oil cooler is going out ect-192 eot-219 and bam 260icp psi and don't know where to go from here
