1 - 5 of 5 Posts
I was wondering if anyone knows of a good forum to learn more about serveillance equipment for homes.
Also, if you have a home serveillance system and can give me any pointers or suggestions that would be great!
I am really intersted in getting a system that will record video so I could use it in case something does happen. I would also be interested in a system that I could monitor remotely. I know there are a bunch of options that I can do I just need to learn more about the equipment and I'm not sure where to start...
Google home alarm system forum, home security system forums. I have lurked on a couple of sites but nothing jumped out as the go to site. Much will depend on brand of equipment used.
All done now
Look for PC based equipment. Basically an expansion card with 4 BNC connectors for cams. Some software to make everything work. You supply your own cams and cable. You can monitor most of those over your internet connection.
stroker newb
thehighroad.org
Its a gun forum, but there's also quite a bit about home security. A lot of knowledge there. Also a lot of tin foil hats, but its easy enough to weed them out.
I'm a member and go under the same name there as here.
1 - 5 of 5 Posts
