1 - 20 of 20 Posts
Ok so i am a fairly new 7.3 owner, and i drive alot of highway miles. I used to drive at 75mph but since i got my F-250 i only drive at about 69mph cuz of how high the rpms are at 75. I know these engines are beasts, so i was wondering if it will hurt the engine in any way if i set my cruise at 75mph? :confused:
I am pretty sure that it has 3:73, but i am not positive, is there anywhere on the truck that it specifies. at 69mph my rpms are at about 2100-2200
All done now
Sounds like 3:73's
Ok good, cuz i was just a little worried that cruising with the rpms up that high might damage the engine, but it sounds like it will be fine.
Nope wont hurt anything... ive put mine on cruise around 80 before. but usually keep mine around 70 for fuel mileage...
Canadian Stroker
They relay smooooooth out over 80:ford:
There is a tag on the diff attached by one of the bolts. A lot of #'s look for 3.73 or 3L73 which is limited slip.
We put the FU! in FUN
mpg would be the only thing i would be worried about.. Thats why i cruise @ 62-65mph
Discussion Starter #15
Yay mine says 3L73! woohoo! :ford: What about posi? did any of these come with it? :confused:
Most poeple refer to a limited slip as a posi. Actually a limited slip other than a detroit trutrac has clutches in it that transfers traction to the side thats spinning. A tru posi is a locker. Both sides are locked together.
What you have is a fact limited slip. Which is good. If it ever needs replaced put a trutrac in it.
you can tell your gear ratio by jacking the back end up and rotating the tire and every turn of the tire the drive line will turn about 3 3/4s turns and so on.so the ratio is 3.73 to 1.
Discussion Starter #18
Ahhh i see, thanks for the clarification ;), well it seems to be pretty much always locked so i figured it was a posi/limited slip. Works good in mud! :evil
I run my van at 80mph all the time, fuel economy is def down compared to 65mph but I get bored driving 60miles one way to work and can't keep the speed down, btw it's got 3:55's with 245/85/16's on it.
1 - 20 of 20 Posts
