1 - 4 of 4 Posts
I am looking for a part number for the small plug that is in the valley of the engine. Takes a 5/8 wrench to remove. Also you remove two of these to install the cross over hose. Also is this a 1/2" straight thread fitting. I want to pressureize the head to see if I have oil leaking by the injectors back into the head. Thanks Dave
Crazy *******
-05 ORB
If you walk into any hydraulic shop, thats all they need to know, then you can get to most any other thread that you want.
If you need an adaptor, you could say, "I need a 1/8" fnpt x -5 morb"
Good luck
Marc
Marc
That is perfect, Also helps me with the plugs as well. I might even have something kicking around in the toolbox as well.
1 - 4 of 4 Posts
