1 - 6 of 6 Posts
has anyone ever seen a high pressure oil line blow off at the oil rail on a 2003 6.0 what did it sound like when you tried to crank the engine over after the line blew off ??? and if this did happen could the hpop make enough pressure even with the oil line off on one side to make the other side of the engine try and fire
09 6.4
im sure it's possible for the line to blow off, considering it just a STC fitting on the end. the HPOP wont be able to provide enough pressure to start in its blown. it'll just leak out.
Once started the trucks can run with low, high pressure oil supply (althou not well). It is during starting it needs the higher pressure to turn on the FICM.
1 - 6 of 6 Posts
