1 - 13 of 13 Posts
Big Plans
Does it leave some HP's on the table with only stock fuel? Are the chargers way under their optimal output?
it leaves a lot on the table...Mike D had that set up on Godzilla and could tow anything he wanted on xtreme tunes and not get over 1100 degrees on his egt's
It has a huge potential for more fuel, but from what it seems, the set up is reliable, fun, and able to light faster than stock turbos
Cab on installer
Of course it does. But you can tow anything and your egts are super low.
Discussion Starter #9
http://www.youtube.com/watch?v=ZUbBGQYqMmQ&feature=related
Damn! That thing is badass! I like the fact that you can do fuel mods later if you want to go bigger. Plus it clean up the smoke big time. Gunna need a valve train upgrade for sure, probably up pipes, what else would a guy need to make this a reality?
StackinChipsLikePringles
Its a VGT turbo. Why would you need fuel
1 - 13 of 13 Posts
