1 - 13 of 13 Posts
Guys I'm lost i have a high pitch squeal coming from the turbo side of the engine. It doesn't do it all the time but when it does it goes away once my turbo spools. It mostly does it after you drive it for a little and at idle.
i will be taking it apart tonight to figure it out. Im just trying to find a place to start. Im gonna take off all the rubber boots and make sure there are no cracks or leaks.
Busy Busy
Look at your uppipes.
Put a truck back together last week, drove it. Customer got here and as soon as we went to drive it suddenly had a squeal at 10psi. Small crack in bellow of uppipe.
This is not the first time something like this has happened to me. Anytime you install an egr delete or move the pipes around after they have been set up, they have a chance of cracking.
Back in the 6.oh-no
Yea more than likely the y pipe, mine was extremely annoying when it was cracked haha
thanks guys i will be taking it apart most likely on friday or saturday. How much are up pipes going to run me if i need to replace them.
Busy Busy
Depends...... 200 or so depending on what all you replace.
Don't just replace parts, diagnose first.
Busy Busy
If it's been off before, a lot less time then if it hasn't been.
If it has, 4 hours to RnR....
1 - 13 of 13 Posts
