2001 F450 crew cab with flat bed. Needing to lower my oil temp when hauling stock in the mountains. last time it was pretty warm, probably 80 Degrees outside. this trip includes two steep, long, passes. oil temp reached 249 by the time I would reach the summit. I've flushed the cooling system and added new coolant and additive. Is there a good miracle in a bottle to flush the engine and oil cooler, or should I pull the oil cooler to clean and check. Is there any other ways to get the oil temp down. I do have an edge tuner that I just run in tow mode, otherwise every thing else is stock, except for a 6.0 tranny cooler. Any suggestions would be appreciated. Thanks
