1 - 6 of 6 Posts
Problem started after i did my egr delete. Getting codes p0470,p0472,p0478. I am getting 20-30 lbs of boost at 1/4 throttle. Could this be due to a bad ebp sensor?
Could be ebp or stuck turbo vains have you tried cleaning the ebp tube?
No i just ordered a sensor and was going to clean the tube when i replaced the sensor. Can a clogged tube cause this turbo issue?
Checked my exhaust back pressure psi with my edge in sight cts and it is constantly at 36 and if I unplug the sensor it is at 4.
1 - 6 of 6 Posts
