What are you numbers on what kind of a setup and altitude? Trying to find out whats normal.
Wondering because I was towing about 6500 last weekend and the EGT on stock sticks and stock tunes would hit 1200 and stay steady running WOT on a 4% grade @about 70 mph. This is at 6000 ft.
I'm sure thats higher than normal but I found both intake plenums leaking. The pass side was leaking about 3/4 of the way along the top and I resealed it tonight, the drivers side I'll do tomorrow night, it was only leaking under the hose inlet.
BTW it runs 17 psi for boost with the leaks.
Thanks
Thanks
