1 - 2 of 2 Posts
I’m installing HID low beams and LED high beams on my FIL 2011 f250 with after market headlight housing. I’m using a relay to power HIDs and high beam turn on to turn low beams back on when highs are turned on. Now the high beams are not coming on at all. The fog lights cut off, the shifter clicks when pulled back, and the high beam indicator turns on in das, But no power at high beam plug behind headlight. I have power at fuse 39 on one side but not the other side. Low beam fuses 16-17 have power on both sides.
Is there a relay somewhere? I’ve looked in the book but don’t see anything for lights except for fuses. Can anyone shed some light on what I’m missing?
Discussion Starter #2
NM, I thought I had checked the fuse with a new one in it but I didn’t. Fuse 39 blew. But now I have to check my wiring and see why the high beams still aren’t working.
1 - 2 of 2 Posts
