1 - 7 of 7 Posts
· All done now
That's what I like in a mudder, all business, looks don't count. Nice truck, looks like crap though. I had a 1972 Dodge 3/4 ton that was just like it.
Betcha when your daily driver breaks, the Bronco always gets you where you need to go, right.
· you want some of this?
Cool bronco! 347 right?. You do the 44 up front, 9" rear ? Auto?
I started out with a EFI 5.0, c-4, and stock running gear. Rearends didnt last long. Went to a 9", then a 44 up front, locked front a rear. After the c-4 gave up the ghost, I went c-6, then after much NOS, the 302 popped a head gasket. (mad at girlfreind):doh:. Buildup really started then. I built a 393 ci windsor stroker, with victor jr. heads, the high rise victor efi, big honkin injectors, .600- .625 lift cam with around 310 duration (hyd. roller.)
Went with flat top 302 wiseco's, giving it around 11.5-1 comp. (too much for pump gas)MSD, L&L headers, and a bunch of other crap. UHhhh, then the c-6 took a crap. Tired of fighting with auto I went to a np 435 heavy $$$ cast iron 4 speed granny gear.:ford:. Tough as nails, just no more drag racing.
Fun on the rocks though! Never let me down since the straight gear.
Funniest thing- I used to pull a 24 foot enclosed with the 302/ c-4, and it was faster on take off WITH the trailer than my dads old 6.9 dually unloaded.:pointlaugh:. I miss the good old days.:(
· Registered
Discussion Starter · #4 ·
Its a 44 and 9" 4:56 gears spooled F&R. 347 stroker MAF, injected. No gas for me though!! Believe it or not it has 53cc 289 heads on it, so the compression is up there! I run a performer cam because i need to pull vacuum to run the class i am in. ;)
And yes Arisley its all business, and looks like crap but i surprise a lot of people at the bogs with it.:D
· All done now
Yep, I used to own a '63 Plymouth Belvedere, that looked like a POS, but ran like a raped ape. 318 big block, bored 60 over. Made a lot of pretty cars llok bad.
1 - 7 of 7 Posts
