1 - 2 of 2 Posts
My truck started last werk but today it sounds really weird and wont start! It seems to be turning over faster than normal and occasionally itll slow down too a stop for a second and start spinning again! I know in a gasser all the signs point to a timing issue of some kind! Also i tried to crank it a couple times and realized it was out of oil so i topped it off hoping that was the problem but ive been cranking it for 2 hours and still nothing... Thanks ahead for the input👀
What was out of oil, the crankcase or the HPOP reservoir (or both)? Any CEL? Take a good look at the IPR wiring, make sure the tin nut is there holding the IPR coil on snug, and that there is 12V at the IPR plug when the key is in RUN. If you did run out of oil, you may have air in the HP oil system which may take some time to get started again. You could also have some bad injector O-rings causing pressure not to build. Cheers!
1 - 2 of 2 Posts
