My truck broke down today for no apparent reason. its a 2001 f-250 superduty 7.3L with only 65,000miles on it. well taken care of. nothing after market except afe stage 2 air intake.
No check engine lights are on. all it will do is turn over. we replaced the fuel filter, (which was dirty as hell). when we put the new filter in it started for a little while and then died suddenly as if someone turned the key off. so we took the filter off again and drained the fuel out of the filter bowl, and check to see that diesel was flowing, which it was. then we put the filter back in and it started again and died. same senario! during this period the check engine light came on once and went off. Dont know much about diesels, and deffinatly dont wanna take to the dealer.
Could it be bad injectors? If so i upgrading. :ford:
I could use some info.
If you need to know any additional information just ask. and thanks!
