21 - 23 of 23 Posts
Could be the wiring from IDM to injectors, injector solenoids, or IDM. Have you done the tests in the attached? Cheers!
Discussion Starter #22
Awesome thanks for the link I’ll be sure to to check all the wiring and everything in that diagnostic test ... could a bad Idm cause only a couple of bad injectors on the buzz test you could definitely hear a difference in buzzes if you paying attention .... or am I also possibly looking at bad injectors
Discussion Starter #23
Okay I did the test that you linked all wiring seams good first test was 2.5 ohms all the way across it said normal resistance is 2.9 and on the left said it should be between 2.8-3.6 ohms does that mean all injectors are bad
21 - 23 of 23 Posts
