1 - 11 of 11 Posts
Changed the fuel filters in the truck. primed it by turning the key on for 5 times for 30 seconds and it wont start. primed it again 5 more times, started for about 5 seconds and died. Can't get it started:(. Anyone have any ideas?
no.. i did the engine mount first and then the frame mounted filter.
Take the air filter off get a rag soak it in gasoline hold it over the air intake start the engine
thanks, I'll give it a shot in the am
whistle tits
or if you want to properly do it, take an old air chuch, hook it to the schrader valve under the hood near the fuel cooler iirc, and with a hose hooked on to it, let it drain into a bucket while you cycle the key until all the air is bled out
Thanks guys, the gasoline on the rag wouldn't work so I went to the auto parts store and bought some starting fluid. That worked but I got a P1336 camshaft sensor range performance code after starting it? truck seems to be running ok so I cleared it and will see if it comes back.
Glad to hear it's running
Bleed air off at fuel cooler schrader valve. Use screwdriver and a towel.
Have a second person cycle key a few times, until no more are is present.
Works great for me.
1 - 11 of 11 Posts
