1 - 3 of 3 Posts
Hillbilly
Just what the title says I started the truck shifted out of park and lost all the gears the shifter will move but the truck will not go into gear
Prob popped off the side of the trans, lay underneath the truck and you'll see the linkage on the side. All the way forward is park
Mine did something similar and it was the box that mounted to the underside of the steering column. The bolts just backed out and allowed it to slide around a bit.
1 - 3 of 3 Posts
