1 - 7 of 7 Posts
Checked my truck today for any codes and this is what I got: P2291 INJECTOR CONTROL PRESSURE TO LOW-ENGINE CRANKING WTF! Is this something I should bring to the dealer or can I fix it? Any help would be great.
Thanks
FYI, THIS IS MY FIRST FORD SO I DONT NOW #### ABOUT THIS MOTOR!
spoolin heavy!!!!
Sounds like ur icp is junk.......If ur truck is late 2004 to 2007 it's on ur pass valve cover right up front. Easy to change ......But it's also a common code for trucks with out ford updated items because it could also be the stc fitting in hpop is blown out ford updated it to a 1 piece..... Could be a leak in the oil rails under the valve cover which could need either or both ford updated stand pipes and/or updated dummy plugs....... U can test by removing icp sensor and hook shop air to it and see where it leaks
I might try that. I talked to a guy yesterday about bringing my truck in for the 10 other things that are wrong and he said he will test it for me and let me know. thanks again for all your help.
1 - 7 of 7 Posts
