1 - 2 of 2 Posts
Fire junkie
I have a problem I cant figure out with the power windows in the car:doh: I use to drive back and forth to work (hey its 80 miles round trip and it gets 30mpg) anyway.....the drivers window sometimes will not go up or down, front passenger I can roll down but not up (from pass. side it will go up/down, drivers side rear will not go up or down from drivers control or at door itself, pass. side rear door will sometimes go up/down from drivers door, up/down from door itself, I though it mite be the control it self so I got a used one and it does the same thing, I have check all the fuses (good) and the conections in the doors both switch and to motor, any ideas were to go now??????
Thanks
Roy
my guess is the wiring in the drivers door to car body is starting to fail, and the wiring on some window control switches is such that all switches need to be hooked up to operate the window. someone else will help more.
1 - 2 of 2 Posts
