I have a 2003 F-250 with a 6.0 that is driving me nuts! I have been running my SCT with the MKM Customs canned fuel economy tune for about a month. The other day I changed to the street performance tune. Driving around town it felt great. After about 30 mins of driving I decided to try it out with a little skinny pedal. It got to 2500RPM and just seemed to stall there. Anything more than about 50% throttle it seems to have no power, some grayish/black smoke (no white or blue). Almost feels like its flooded. I returned it back to stock to see if maybe the tune was bad and it behaves the same. I don't think it had anything to do with the tune. This is my wife's daily driver and she doesn't drive it hard, so it is very possible that cruising around town she never triggered the problem (or never noticed it).
A little background info:
Truck has 225,000 miles on it. I did studs, oem gaskets, upgraded oil cooler, egr delete, exhaust, fuel regulator kit, new turbo drain pipe, new stand pipes, etc... Basically everything possible from every TSB dating back to '03. I did this in my shop about 20,000 miles ago and I have had "0" issues since then.
So at WOT the boost is about 25psi, you can hear the turbo spool until about 2500 rpm's and then all I can hear is the engine. It almost sounds like its "gargling".
I have pulled and cleaned the EBP sensor/tube just in case. Batteries are fully charged, checked all turbo boots hot and cold side. Changed fuel filters, oil is 2000 miles old and level is good.
I'm thinking there is a problem between the HFCM and the Pressure regulator. I can hear the pump changing pitch when I pump the brakes (weird I know) also it intermittantly cavitates and when I shut off the truck I can hear fuel gurgling back down from the filter under the hood (don't know if this is normal). I am going to put a gauge on the test port this afternoon and see what my pressure readings are.
If they check out good are there any suggestions as to where I go from here? Need help guys, I don't want my wife stranded somewhere because I failed to fix her truck. (I'd be in big trouble)
