HELP!!!HELP!!!HELP!!!2005 Ford 6.0 truck will run smooth for as long as you let it idle, once you start to go down the road and get it under a load it will die out like its starving for fuel and will not restart. FICM volts is 48 builds up over 500. fuel pressure is at 60 psi and drops down to 45 while cranking, no codes what so ever.
update:
This morning when i got here i tried to crank it up again. it crunk up for just a few seconds and then died, i was able to pull up the power balance and the truck was running rough and it showed cylinder#1 was dropped and cylinder #3 was also low. again icp was building up to 600 psi then maxing out. i decided to unplug the ICP sensor and watch the ipr Duty cycle. with the ICP plugged in it was around 56% when i unplugged the ICP sensor the IPR maxed out at 69% generally i have seen them max out at 89 i dont want to just throw parts at it, any help would be nice. just never had an ipr cause this type of issue
update:
