1 - 1 of 1 Posts
Ok , Sorry if Im reposting ,
I really don't want to take my truck to the dealership 2003 F350 6.0
replaced the starter ( had a cracked solenoid)
then noticed the fan clutch assembly got caught and cut by fan
towed truck home
had starter replaced ( replaced 22 fuse )
started truck and moved to driveway
repaired the wiring of fan clutch
truck no longer cranked ( no fuel pump noise)
hooked up wire on passanger side of truck to battery starter cranks
unplugged fan clutch.. still no crank
checked fuses none are burned out
bought new relay for starter and still nothing ( i hear it click when i turn the key)
took off ignition switich and manually pushed the switch and still nothing
i have no idea what a pcm or other things' was told to unplug and check are
NOT A MECHANIC
ALL HELP IS APPRECTIATED
1 - 1 of 1 Posts
