1 - 4 of 4 Posts
I have a wiring issue. can anyone advise me about the connection of the yellow wire running out of the alternator. Where it Connects, If it is normally positive or negative and if positive, is it only when the key is on. It currently ran to the glow plug relay, but I think that had something to do with the command start install. In any case I don't know which terminal on the glow plug relay that it should connect to.
Can anyone help?
Thanks for the info. I'm not sure why the previous owner re-wired it. probably trouble with the fusible link. in any case I rewired to the positive post on the glow plug relay (fuse inline). Working great.
1 - 4 of 4 Posts
